Tutorial: Joints, Motors, and Plotting
Create and modify joints, add angle and speed motors, then run a motion analysis and plot the results.
In this lesson you will learn how to:
  • Ground a part
  • Connect parts with joints
  • Modify the joint state
  • Add angle and speed motors
  • Run a motion analysis
  • Plot motion results
Open the CAD model
  1. Press F7 to open the Demo Browser.
  2. Double-click the M10_DoubleUnivJoint.x_t file in the Motion folder to load it in the modeling window.
  3. If not already visible, press F2 to open the Model Browser.
  4. Check that the unit system is set to MKS
Ground a Part
  1. Select the Motion ribbon.
  2. Hover over the Ground tool and click the satellite icon to open the Ground Parts table.
  3. Select the Ground check box in the table for the Base part to ground it.
    The part turns red, indicating that it is a ground part.
  4. Close the Ground Parts table.
  5. Right-click and mouse through the check mark to exit, or double-right-click.
Connect Parts with Joints and Modify Joint State(s)
  1. Select the Joints tool.
    The guide bar appears with default settings (All, Auto).
  2. Click the button on the guide bar.
    Notice that joints are created at neighboring parts in the model, with colors used to indicate the joint state.
  3. Select the blue hinge Joint 6 located at the Mount 1 and Yoke part connection near the input crank.
  4. In the microdialog, change the joint state from Locked to Active.
    This will allow the yoke shaft to spin inside its mating hole on the mount.
  5. Select the blue hinge Joint 12 located at the Mount 2 and Yoke part connection near the output wheel.
  6. Again, change the joint state from Locked to Active.
  7. Click on the green planar Joint 10 located at the part connection between the Output Wheel and the Output Cap.
  8. This time, change the joint state from Active to Locked.
  9. Right-click and mouse through the check mark to exit, or double-right-click.
Add Angle Motor(s) to Control Part Angles
  1. Select the Motors tool.
  2. Rotate the model to see the underside of the Base part.
  3. For the first connection, click the Cen (center) snap point on the circular face of the Mount 1 part.
    The selected feature turns red. This is the shaft connection point.
  4. Click on the Base part.
    This is the base connection for the motor.
    A motor appears and the microdialog has the default setting of being a speed motor.
  5. In the microdialog, change the motor Type from Speed to Angle.
  6. Notice that the magnitude field now contains 45 degrees as the default angle.
  7. Click the +/- button to reverse the direction of the motor's rotation.
  8. Change the Profile Function to Step Dwell Step.
  9. Pan the model over to the other end of the Base part and click the Cen (center) snap point on the circular face of the Mount 2 part.
  10. Click on the Base part.
    Another motor appears, with the same settings as the first motor.
  11. Click the +/- button to reverse the motor's direction of rotation.
Create a Speed Motor to Drive the Mechanism
  1. While the Motors tool is still active, click the Cen (center) snap point on the face of the handle part.
  2. Click on the Mount 1 part to create the motor.
  3. In the microdialog, make sure the motor Type is set to Speed.
  4. Make sure the Profile is set to Step in the microdialog.
  5. Click on the chevron in the microdialog to open the advanced motor options.
  6. Click the icon to open the Move tool.
  7. Move the motor away from the handle, offsetting it in the Z direction (the global -X direction).
  8. Right-click and mouse through the check mark to exit, or double-right-click.
Run a Motion Analysis to View Mechanism Behavior
  1. Position the model as shown below.
  2. Click the Quick Run button on the Analyze Motion icon to see the model in motion.
    Notice that the ground parts remain stationary and some of the unconnected parts fall down due to the effect of gravity.
  3. Click the Quick Run button again to stop the analysis (if it is still running).
  4. Double-right-click, or click the Review Motion Results icon to exit review mode.
Modify the Angle Motors Using the Motors Table
  1. Rotate the model to view the underside of the Base part again.
  2. Hover over the Motors icon, then click the List Motors tool to open the Motors table.
  3. Select Locked for Motor 1.
  4. Change the angle Value for Motor 2 to 5 deg.
  5. Click the List Motors tool again to close the table.
Perform a Motion Analysis and Plot Results
  2. Click the Quick Run button on the Analyze Motion icon to run the new motion analysis with the first angle motor being locked and the second angle motor rotating 5 degrees.
  4. Select the big speed motor, Motor 3, to plot the results.
  5. Right-click on the plot and select Speed (Desired vs. Actual).
    Notice that there is some oscillation due to the controller being unable to meet the desired speed perfectly.
  6. Right-click and mouse through the check mark to exit, or double-right-click..
Disable the Controller on the Speed Motor
  1. Double-click on Motor 3 in the graphics window to edit it.
  2. Deselect the icon in the microdialog to disable the controller.
  3. Right-click and mouse through the check mark to exit, or double-right-click.
Rerun the Analysis and Review Results
  1. Click the Quick Run button to analyze the mechanism with the controller disabled. Click the stop button to stop the analysis.
  2. Select Motor 3 to plot the results.
    Notice that the desired speed matches the target speed and the oscillations seen previously with the controller are no longer present.
Rename Joints and Plot Results
  1. Click the List Joints tool on the Joints icon.
  2. Select Joint 6 in the table, then double-click to rename it Joint 6 @ Crank.
  3. Select Joint 12 in the table, then double-click to rename it Joint 12 @ Flywheel.
  4. Close the Joints table.
  5. Select the Review Motion Results tool on the the Analyze Motion icon.
  6. Press the F2 button to open the Model Browser and select the Joint 6 @ Crank.
  7. Right-click on the plot that appears and click Angular Velocity.
    Notice that the curves for input shaft velocity are smooth.
  8. Select Joint 12 @ Flywheel in the Model Browser and view the plot.
    Notice that the curves for output shaft velocity have oscillations, as expected, due to the 5 degree angle being imposed at Mount 2.
