Load Results and Plots
Visualize contours, animations, and plots for each run in the modeling window.
Do one of the following:
- From the Design Explorer ribbon, Evaluate tool group, click the
Results Explorer tool.
- In the Results Explorer browser, click the Summary Table icon .
Run Status satellite icon
- After submitting a simulation, this dialog will open automatically.Note: Using this dialog, individual runs can be contoured while the simulation is still in progress. Animations are not supported from the Evaluation Status dialog.
Right-click on a completed run and select Load Results
or Load Plots.
The Results Explorer uses HyperWorks X' full featured post-processing environment to display contour, animation, and plot results. The first-time results or plots are loaded, a second window, either animation or plotting client, is opened and the results or plots are loaded. You can add additional pages or configure your page layout to add additional animation or plotting windows as desired and load results or plots into the appropriate windows.
- Select desired result or plot options using the contour, animation, or plot controls.
