Optimization Summary Table Data
The optimization summary table shows the design variable values along with the calculated objective and constraint values for each run.
General Column Data
Column Color Coding
The Optimization Summary table uses color coding to help you determine which designs are feasible, optimal, and violated. If an iteration contains a violated constraint, the violated constraint is displayed in a bold font.
White Background/Black Font
Feasible design
White Background/Red Font
Violated design
White Background/Orange Font
Acceptable design, but at least one constraint is near violated
Green Background/White Font
Optimal design
Green Background/Orange Font
Optimal design, but at least one constraint is near violated
