Set Up and Run a CFD simulation
Run a CFD simulation using default or custom settings.
CFD Quick Run
Use the default settings to run a CFD simulation for the selected parts.
  1. On the Fluids ribbon, click the Run CFD Simulation button in the Analyze CFD tool group.
  2. Let the analysis run to completion.
Custom CFD Run
Run a CFD simulation with custom settings.
  1. On the Fluids ribbon, click the Custom CFD Run tool in the Run CFD Analysis tool group.
  2. Customize the settings:
    Table 1. Simulation tab
    Option Description
    Name Enter the name of the simulation.
    Low-High Resolution Drag the slider to the left for a fast, low resolution simulation. Drag the slider to the right to increase the resolution.
    Voxel Size Define the size of the voxel mesh used for the calculation.
    Estimated No. of Voxels The approximate number of voxels in the mesh used for the calculation.
    Max. Facet Size Enter the facet size of the surface mesh used to visualize the results.
    Curve Chord Angle Define how closely the curve is approximated with straight sections in the mesh. For a finer mesh, decrease this value. For a coarser mesh, increase this value.
    Table 2. Advanced tab
    Option Description
    Termination Criteria Stop the simulation when the selected criteria are met.
    • Physics and Equations: Stop the simulation when both the Physics and Equations criteria are met.
    • Physics or Equations: Stop the simulation when either the Physics or Equations criteria are met, whichever occurs first.
    • Physics: Stop the simulation when the Physics convergence criteria are met.
    • Equations: Stop the simulation when the Equations criteria are met.
    Convergence Speed Control the time step size used to pursue a steady solution. Larger values may lead to instability for some simulations.
    Max. Time Steps Define the maximum number of time steps allowed in the simulation.
    Flow Type Select a flow type.
    • Turbulent: Turbulent flow is characterized by chaotic particle movement. Most engineering flows of interest are turbulent.
    • Laminar: Laminar flow occurs when a fluid flows in parallel layers. This only appears at very low Reynolds numbers.
    Note: To restore the default settings, click the Reset button and select Defaults.
  3. Click the Run button.
実行状況
現在の実行の状況をビューするには、現在処理中の実行のほか、まだ結果表示していない現在のモデルでの実行も表示されます。これまでのすべての実行を確認するには、実行履歴を使用します。
  1. 解析アイコンにマウスカーソルを合わせ、実行状況ツールを選択します。
    実行状況ウィンドウが表示されます。
  2. 実行の完了後、そのステータスを確認します。
    ステータス 説明 メモ
    実行は正常終了しました。 この状態は、解析アイコンの上に緑色の旗が表示されていることでも示されます。緑色のフラグをクリックして結果を読み込むことができます。
    実行は不完全でした。
    解析を実行しましたが、不完全な状態で終了しました。結果タイプのすべてではなくても、一部は有効である可能性があります。新規の解析を実行して完全な結果を生成することをお勧めします。
    最適化を実行すると、実行は完了しますが、警告または違反が報告されます。実行状況ダイアログで実行の名前をダブルクリックします。続いて形状比較で制約違反ボタンをクリックして詳細情報を確認します。
    計算はエラー終了で有効な結果はありません。 この状態は、解析アイコンの上に赤色の旗が表示されていることでも示されます。
  3. 1つまたは複数の実行を表示します。
    • 実行を表示するには、その行をダブルクリックします。
    • 複数の実行を表示するには、CtrlまたはShiftを押したまま行をクリックしてから結果表示ボタンをクリックします。
      注: 同じパートに複数の結果が関連している場合、そのパートの最も直近に実行された結果がモデリングウィンドウでアクティベートされます。
ヒント:
  • 実行が保存されているディレクトリを開くには、実行名を右クリックして、実行フォルダを開くを選択します。
  • 削除した実行または過去に表示した実行を表示するには履歴ボタンをクリックします。
  • 実行を削除するには、実行を選択し、削除を押します。解析エクスプローラまたはモデルブラウザで右クリックすると表示されるコンテキストメニューを使用して、実行の削除も行えます。
実行履歴
現在のモデルと以前のモデルに対するこれまでの実行を表示、ソート、開くか、削除します。
解析実行を表示すると、実行状況ウィンドウから削除されますが、実行履歴テーブルを使用して表示できます。
  1. 解析アイコンまたは解析CFDアイコンにマウスカーソルを合わせ、実行状況ツールを選択します。
    実行履歴が表示されます。
  2. 実行のステータスを確認します。
    ステータス 説明 メモ
    実行は正常終了しました。
    実行は不完全でした。
  3. 実行を表示するには、その行をダブルクリックします。
ヒント:
  • 実行が保存されているディレクトリを開くには、実行名を右クリックして、実行フォルダを開くを選択します。実行履歴が保存されるデフォルトディレクトリは、実行オプションのプリファレンスで変更できます。
  • デフォルトでは、実行履歴が一定のサイズを超えると通知が届ききます。サイズ制限を変更するか、実行オプションのプリファレンスで通知をオフにできます。
