Adding a Folder
To add a folder
On the Navigation Tree, click Server Library and select Folders.
Click
on
the Folders page. The Folders page appears. -
Enter the name of a folder in the Name field.
Enter the description of a folder in the Description field. This step is optional.
In the Available Models section select models that you want the user to have access to.
To add a model drag it from the left pane to the right pane or click
icon next to its name. -
To remove a model drag it from the right pane to the left pane or click
icon
next to its name.
Note: You may also use Add All and Remove All controls.
In the Available Templates section select templates that you want the user to have access to.
To add a template drag it from the left pane to the right pane or click
To remove a template drag it from the right pane to the left pane or click
Click Save to save all settings done.
You can build server library folders hierarchy. Inside a folder of the
root level, there might be several levels of enclosed or nested folders.
To add a nested folder
Open the required folder of the root level on the on the Folders page.
Define the level of the nested folder in the Hierarchy level tree.
Perform actions for available projects, models, templates, specified in the previous procedure (Adding a folder).
Click Save to save all settings of the nested folder.
When server library folders hierarchy created, on the dialogs for selecting models and templates, all these models will be displayed as a tree.
