Adding a Log Clearance Task
To add a log clearance task
On the Navigation Tree, click Report Warehouse, then click Maintenance and select Log Clearance Tasks.
Click
on the Log Clearance Tasks
page. -
Maintenance Task Name: Enter the name of a new log clearance task.
Description: Optionally, enter any text defining the clearance task.
Date: Specify the dates of events to be deleted by the current task in the From ... To boxes. Click
to use the Calendar. -
Please, select Tables for clearing: Specify the table to delete records from.
Select the event types or the job log statuses to delete from the specified table.
Select All: Click this button to select all options.
Select None: Click this button to clear the selection.
To save a new log clearance task, click Save.
If the operation is completed successfully, the system saves the a new task to the database and displays the updated Log Clearance Tasks page. -
To clear the recent changes, click Clear.
To cancel the operation and return to the Log Clearance Tasks page without saving data, click Cancel. Keep in mind that no changes will be saved.
