Adding a Model
To add a model
On the Navigation Tree, click Server Library and select Models.
Click
on the Models
page. The Model page appears. -
Enter the name of the model file in the Name field.
Enter the description of the model in the Description field. This step is optional.
To enter the path to the model file in the Model field, click the Browse button, and select the model file.
Enter any comments if necessary in the Comment field.
To save a model, click Save.
The system saves the new model to the database and displays the updated Models page, if the operation is completed successfully. -
To reset the recent changes, click the Clear button.
To cancel the operation and return to the Models page, click the Cancel button.
To upload a model
Click Upload Models on the Models page.
Click Add Files to browse to a model file or drag and drop model file in the Drop files here area.
To replace model file paths
Expand the Replace Paths section. You will see a list of external models and lookup files. Those files that could not be found are marked with a warning sign.
Click the Browse button for the file, select the file path, then click OK.
Select the Replace checkbox for the file you want to replace path.
Click the Save button.
