Deleting a Maintenance Process
If you no longer need a maintenance process, you can delete it.
To delete a maintenance process
On the Navigation Tree, click Report Warehouse, then click Maintenance and select Maintenance Processes.
Click
at the end of the row with the maintenance process you want to delete. -
Click Delete to delete the maintenance process from the list.
