Deleting a Template
You can delete a template from the system via the Templates page.
Note: You cannot delete a template if it is currently assigned to a document type. You must first remove it from the document type in order to delete it from the system.
To delete a template from the list
On the Navigation Tree, click Server Library and select Templates.
Click
at
the end of the row with the template you want to delete. A dialog
box appears. -
Click Delete to delete the template from the list.
Note:
If a template has the Locked
status (
), it cannot be deleted. First unlock
the template and then try again.
