Editing a Hyperlink
To edit a hyperlink
On the Navigation Tree, click Report Warehouse, then click Document Management and select Document Types.
Do one of the following:
Click the name of a document type, to which the hyperlink is assigned.
Select the document type, by clicking anywhere on the row, and then click
Select the Hyperlink tab at the top of the page.
Click the name of a hyperlink that you want to change.
Select the hyperlink, by clicking anywhere on the row, and then click
The Hyperlink page appears.
Make the necessary changes.
Click Save. The system saves the modified hyperlink to the database and displays the updated Document Type page, if the operation is completed successfully.
