Filing Report
A Filing Report is one of transaction reports provided by Monarch Server. This report provides the following information:
Date and time when each filing process and task began and finished running.
Names of filing processes.
Filing task(s) assigned to each process.
Error message for any task or process that failed to run.
To view and print a Filing transaction report
On the Navigation Tree, click System Reports and select Transaction.
Click the Filing link. The Filing Report page is displayed.
In the From ... To fields specify a time period, for which you want to view the filing actions. Click
to open the Calendar window, and
select the date.
Note: If you do not provide a date or time period, all filing actions will be displayed.
Click View. The Filing Transaction Report is displayed.
To print the report, click the
icon
at the top of the page, then click OK
in the Print dialog box.
Note: For information on how to convert a report to another format, see Converting a report to another format.
