Full Text Search
All results of the maintenance full text search type tasks in the system are listed on the Full Text Search page.
To display the Full Text Search page, click Report Warehouse on the Navigation Tree, then click Maintenance and select Full Text Search.
The list shows:
Search Text: The text you entered while configuring a maintenance task.
Search Date: The date when the search was fulfilled.
Task Name: The name of the maintenance task.
Count: A number of the results found.
Whole Words Only: This field is marked if you selected the Whole Words Only check box while configuring a maintenance task.
Case Sensitive: This field is marked if you selected the Case Sensitive check box while configuring a maintenance task.
You can also:
Select the users to send notification to, by clicking the
icon. -
Delete the result, by clicking the
icon.
