Importing a User Group
You can import user groups from Active Directory of the user under which Monarch Server Agent Service is running. Use the Import Groups button for importing user groups.
The Import Groups button is available if Security Provider is selected from Active Directory and the Monarch Server Agent Service runs as user in Active Directory.
When a user from Active Directory logs in Monarch Server Admin or Client, the system starts checking all groups in the Active Directory in which the given user has membership. The checking is executed by the sAMAccountName parameter. The system checks whether the sAMAccountName parameter matches the Alias parameter of Monarch Server groups. In case of matches, privileges of all Monarch Server groups are granted to the given user during the current session only.
