Input Elements
Input elements in the Process Designer tool are data sources which are used for exporting.
The table below specifies functionality of the Input group elements.
Element Name |
Description |
Properties and Comments |
File Input |
Source text file in some file system |
The Input Path parameter can be filled out manually or using Browse. Actions:
Note: Input files in compressed archive format (e.g., zip and gzip) can be used and specified.
Web Input |
Text file located in the web (FTP/SFTP, HTTP location, HTTPS, Amazon S3 ) |
In the Input Path field, naming macros may be
used. To do this, click the Insert
Macro icon Note: If some web input file requires authentication, you should add the Credentials element and connect your Web Input element with it. In properties of the Credentials element you should specify the User Name and Password parameters. |
Database Input |
Database file |
Then select the required file using the displayed dialog. NOTE: In addition to Excel file types .xls and .xlsx, .xlsb and .xlsm file types may be used as database file input. If the input file is password protected, select the Include password check box and enter the required password in the corresponding field. To select a specific table within the input file to export data to, click the Table drop-down arrow and select the required table. To replace nulls in the table, select the Replace nulls with default values (empty strings, zeros, and default dates (1/1/1970)) check box. To apply filtering to the table during the export, select the Apply Filter check box and click the Change button below to specify necessary filters. NOTE: Filters are not applicable when applied directly to a Workspace-based dataset. To implement a filter for a Workspace-derived export, apply a change list to the preceding Workspace object as part of the load plan selection. Note: When Automator exports the table data, the filter(s) you selected will be applied to it. Only the data that matches the filter's specifications will be exported. To include column names in the table with the exported data, select the First row contains column names check box. To choose an Excel engine, click on the Excel Engine drop-down list, and choose Legacy or Modern. Note: For the Modern Excel engine, password-protected Excel files can be used. Delimiter character — specifies the delimiter (i.e., comma, tab, semicolon, pipe, space, other) used in the file to separate values. If values may run beyond one line (i.e., the value includes a line break), select the Quoted values may contain embedded line breaks check box. Text qualifier — specifies what character is used (i.e., double quote, single quote, none) to enclose values. When Automator encounters this qualifier in a line, all of the text following this character and preceding its next instance is imported as one value, regardless of the delimiter used. Note: If the delimiter is a comma (,) and the text qualifier is a double quotation mark ("), e.g. "Boston, Massachusetts" is imported into one cell as “Boston, Massachusetts.” By contrast, if no character or the single quotation mark (') is specified as the text qualifier, "Boston, Massachusetts" is imported into two adjacent cells as "Boston" and "Massachusetts." Character set — specifies the type of encoding to use when interpreting data. Lines to skip at start — the number indicated in this box instructs Automator to skip n lines before beginning data import. |
Report Warehouse Input |
Reports from the Report Warehouse document type |
You can search for documents using the following search criteria:
Note: If the source file has PDF format, the PDF Password field appears on the Properties panel. You need to enter password if the source file is protected with the password and click Check. The specified password for PDF file will be checked. If the password is wrong or you ignore password check, you cannot use the given input.
Note: It is recommended to use wildcards in the Input Path field to enable using multiple input files or any input file of a particular file type. Use asterisk (*) to replace multiple characters and question mark (?) to replace some single character. For web input files, wildcards can be used only if it is an FTP/SFTP connection, not HTTP.
