Locations Management
To manage your location preferences
On the Navigation Tree, click System Settings and select System Preferences.
On the displayed page select the Locations Management tab.
To set the default location name for all the object that have location as their parameter
Select location name from the Default Location list.
Click the Save button.
To add new location
Click the Add New Location button
and enter the new
location name in the Location field. -
Click the Save button. The new location will appear on the list.
To edit location
Click the name of the location you want to edit or click anywhere on its row, and then click
Make you changes.
To save your changes, click the Save button.
To remove location
Click
at the end of the row with the location you want to delete. -
Click Delete to confirm.
Note: In case of single server installation refer to the Configurator Guide in the Monarch Server Installation Guide to change location settings.
