Maintenance Report
A Maintenance Report is one of transaction reports provided by Monarch Server. This report provides the following information:
Date and time when each maintenance process and task began and finished running.
Names of maintenance processes.
Maintenance task(s) assigned to each process.
Error message for any maintenance task or process that failed to run.
To view and print a Maintenance transaction report
On the Navigation Tree, click System Reports and select Transaction.
Click the Maintenance link. The Maintenance Report page is displayed.
In the From ... To fields specify a time period, for which you want to view the maintenance actions. Click
to open the Calendar window, and
select the date.
Note: If you do not provide a date or time period, all maintenance actions will be displayed.
Click View. The Maintenance Transaction Report is displayed.
To print the report, click the
icon
at the top of the page, then click OK
in the Print dialog box.
Note: For information on how to convert a report to another format, see Converting a report to another format.
