Model Indexes Configuration Report
A Model Indexes report is one of the configuration reports provided by Monarch Server. This report lists all cases when mapping of Monarch Model fields does not correspond to Index Fields due to model changes subsequent to Document Type configuration.
If an exception is encountered, the report will display it in the following format:
ID NAME
101 Document Type Sample
Passenger field is mapped for Document Type Sample, but is not existing in current model.
To view and print a Security configuration report
On the Navigation Tree, click System Reports and select Configuration.
Click the Model Indexes link. The Model Indexes report is displayed.
To print the report, click the
icon
at the top of the page, then click OK
in the Print dialog box.
Note: For information on how to convert a report to another format, see Converting a report to another format.
