PDF Default Print Settings
Use the PDF Default Print Settings page to set your default settings for printing PDF files. To access this page, on the Navigation Tree, click System Settings, select System Preferences, and click the PDF Default Print Settings tab at the top of the page.
The PDF Default Print Settings page contains:
PDF - Font Name: Select the font name from the list.
PDF - Font Size: Select any PDF font size from the list.
PDF - Break Page Every: Enter the number of rows. Zero value — no page break.
PDF - Break Page Every: Enter the number of pages. Zero value — no page break.
PDF - Lines Spacing: Select the value from the list.
PDF - Readahead: Specify the number of text lines to sample in order to determine paper type and orientation of PDF.
PDF - Portrait Limit: Specify the maximum number of characters per line for portrait paper orientation.
PDF - Landscape Limit: Specify the maximum number of characters per line for landscape paper orientation.
PDF - Left Margin: Specify the left margin size for PDF printing (in inches).
PDF - Right Margin: Specify the right margin size for PDF printing (in inches).
PDF - Top Margin: Specify the top margin size for PDF printing (in inches).
PDF - Bottom Margin: Specify the bottom margin size for PDF printing (in inches).
PDF - Annotation Footer Size: Specify the margin space size for annotations (in inches).
PDF - Annotation Font Size: Specify font size for annotations printed in a footer.
PDF - PDF Split Size For Production: Specify the number of pages to be concatenated to produce a final result.
Save: Saves the settings.
Clear: Clears all the boxes.
Cancel: Cancels the settings.
