Running a Filing Process
When a filing process runs, it executes all filing tasks assigned to it. A filing process can be run in two ways:
Manually — To run a filing process manually, click the Run Now button on the Filing Process page. You can do this immediately after you've finished configuring a new process. (Note: When you click the Run Now button, there may be a brief delay before the process actually runs. This is due to a time discrepancy between the server's clock and the clock on the local machine. Processes are run according to the time of the server's clock.)
Scheduled — To execute a filing process at a scheduled runtime, specify the execution frequency for it on the Filing Process page, then click the Save button. The process will be executed at the specified time.
