Altair® Monarch® Server
Theme Management
You can specify color themes for Admin and Client applications on the Theme Management page.
To change the color theme
  1. Click System Settings on the Navigation Tree, and select Theme Management.
  2. Select
    • Admin theme from the list, select a theme for Admin application
    • Client theme from the list, select a theme for Client application
    • RMS Client theme from the list, select a theme for RMS Client application
  3. Click Save.
Note: For the changes to take effect, relogon is required.
