bentDipoles
Add new "Bent dipoles" structure to the geometry.
Inline mode usage:
- bentDipoles -h: Display a help message.
- bentDipoles -n name -p x y z separation firstDipoleHeight firstDipoleWidth firstDipoleLength secondDipoleHeight secondDipoleWidth secondDipoleLength: Creates a new pair of bent dipoles.
Interactive mode usage:
The following steps will be needed in order to create a new pair of bent dipoles.
- Select center [x y z]: Central point of the structure (equidistant to the vertical segment of both dipoles).
- Separation [double]: Separation between dipoles
- Height of first dipole [double]: Height of the first dipole.
- Width of first dipole [double]: Width of the first dipole.
- Length of first dipole [double]: Length of the first dipole.
- Height of second dipole [double]: Height of the second dipole.
- Width of second dipole [double]: Width of the second dipole.
- Length of second dipole [double]: Length of the second dipole.
Example:
Figure 1. bentDipoles example
