cone
This command draws a closed or open cone.
Inline mode usage:
- cone -h
- Displays the help file that summarizes the parameters for this command.
- cone –n <name> -p <center_x> <center_y> <center_z> <radius_bottom> <height> <radius_top> <height>
- Draws an open cone (no surfaces for the bottom and top bases) with the specified parameters.
- cone –c –n <name> -p <center_x> <center_y> <center_z> <radius_bottom> <height> <radius_top> <height>
- Draws a closed cone with the specified parameters.
- Invocation
- cone (only the shell (lateral surface) is drawn) or cone –c (caps of the cone as a solid model).
- Parameters
- Center point of the base, specified in "x y z" format: x y z.
- Bottom radius: radius_bottom.
- Height of the cone: height.
- Top radius: radius_top.
> cone -c
Select center [x y z]: 0 1 0
Set bottom radius: 5
Set height: 4
Set top radius: 3
Result:
