crossHole
Add a new plane with a cross shaped hole in it.
Inline mode usage:
  • crossHole -h: Display a help message.
  • crossHole -n name -p cornerX cornerY cornerZ width height holeThickness holeSideLenght: Create a new cross hole.
Interactive mode usage:
The following steps will be needed in order to create a new cross hole:
  1. First corner of plane [x y z] Corner point of the plane.
  2. Width and height of plane [width height] Size of the plane (width and depth).
  3. Thickness of cross-shaped hole [thickness] Thickness of the hole.
  4. Length of sides of the cross-shaped hole [length] Length of the blades of the cross-shaped hole.
Example:
Figure 1. crossHole example
