delete
This command deletes an object or set of objects from the geometry. It is also possible to delete all the command history.
Inline mode usage
delete -h: Displays the help file that summarizes the parameters for this command.
Interactive mode usage
Invocation
delete -all
Delete all objects of the geometry and the command history.
delete
Delete the selected objects of the geometry.
  • Objects to delete (only when not specifying -h or all parameters). These objects must be selected by left-clicking on them (hold Ctrl to select several objects) or selecting them on the tree view.
When invoking "delete -all", the command will instead ask for confirmation to delete all objects of the geometry and command history. Note that this operation cannot be undone.
