ellipsoid
This command draws an ellipsoid in the geometry.
Inline mode usage
- ellipsoid -h
- Displays the help file that summarizes the parameters for this command.
- ellipsoid –n <name> -p <center_x> <center_y> <center_z> <radius_x> <radius_yz>
- Draws an ellipse centered at the given point, and with the specified radii.
Interactive mode usage
- Invocation
- ellipsoid
- Parameters
- Center of the ellipse
- Radius along the Y and Z axes
- Radius along the X axis.
>ellipsoid
Select center [x y z]: 0 0 0
Set major radius: 3
Set minor radius: 1
Result
Figure 1. Resulting ellipsoid
