explode
Divides an object into a specific number of surfaces.
Inline mode usage
explode -h
Displays the help file that summarizes the parameters for this command.
explode -all
Explode all geometries in the screen.
Interactive mode usage
Invocation
explode or explode -all
  • Objects to explode (when not using the all option).
A box was created prior to the following operation:
> explode
Select objects on screen (Press enter when done) // Select the box
Result
We can see the object representing the box was split into 6 different surfaces:
Figure 1. Resulting tree view after the explode operation
