planarSurface
This option allows the generation of planar surfaces from multiple coplanar lines.
Inline mode usage
planarSurface -h: Displays the help file that summarizes the parameters for this command.
Interactive mode usage
- Invocation
- planarSurface
- Parameters
- Selected coplanar curves on the screen.
First of all, a circle and a rectangle will be created in order to generate a planar surface from them.
> circle
Center [x y z] 0 0 0
Radius (double) 1
> rectangle
First corner of the rectangle [x y z] 0.5 0.5 0
Size [width depth] 1 1.5
Then, planar surface can be created.
> planarSurface
Select coplanar curves on the screen (press enter when done)
Result:
