project
This command projects points and curves onto surfaces or objects. The original points and curves are not modified.
Inline mode usage
project -h
Displays the help file that summarizes the parameters for this command.
project -s <nameToProject1> <nameToProject2> ... –targets <nameSurface1> <nameSurface2> ...
Project the selected points and curves onto the closest points of the target surfaces selection.
project -s <nameToProject1> <nameToProject2> ... –targets <nameSurface1> <nameSurface2> ... -dir <startX> <startY> <start> <endX> <endY> <endZ>
Project the selected points and curves onto the target surfaces selection according to the vector defined by the differences <endX-startX> <endY-startY> <endZ-startZ>.
Interactive mode usage
Invocation
project or project -dir
Objects to project
Selection of points and curves to be projected. They are not modified.
Target surfaces
Selection of surfaces and objects where the points and curves are projected.
Start point
Origin of the projection direction. This parameter is only required when the option -dir is included in the invocation.
End point
End of the projection direction. This parameter is only required when the option -dir is included in the invocation.
We’re going to project a circle onto a sphere by using the two different modes.
The next commands create the objects required for the projection.
command> circle
Center [x y z]: 0 0 0
Radius [double]: 0.1
command> sphere
Select center [x y z]: 0 0 -1
Radius [double]: 2
command>
If no options is included in the invocation, the project to the closest point is done. This projection may modify the dimensions of the resulting curves.
If the option -dir is included in the invocation, two points are required to define the projection direction.
Results
Figure 1. Project a circle onto a sphere
Figure 2. Project a circle onto a sphere by direction
