rectangularChaff
This command creates a new chaff of dipoles. This command is only available when using the Chaff module.
Inline mode usage
- rectangularChaff -h
- Displays the help file that summarizes the parameters for this command.
- rectangularChaff <center_x> <center_y> <center_z> <x_width> <y_depth> <z_height> <number_dipoles> <dipole_radius> <min_length> <max_length>
- Creates a new rectangular-shaped (with the given center and lengths) dipole chaff, each one with a specified dipole radius and a length between the given limits.
Interactive mode usage:
- Invocation
- rectangularChaff
- Parameters
- Coordinate of the center center_xcenter_ycenter_z
- Size x_widthy_depthz_height.
- Number of dipoles.
- Radius of the dipoles.
- Minimum length of the dipoles.
- Maximum length of the dipoles.
>rectangularChaff
Center point [x y z] 0 0 0
Width (X) [double] 1
Depth (Y) [double] 0.5
Height (Z) [double] 0.25
Number of dipoles [integer]:300
Radius of the dipoles [doubles] 300E-06
Minimum length of the dipoles [double] 15E-03
Maximum length of the dipoles [double] 15E-03
Result
Figure 1. Resulting rectangular chaff
