rotate
This command rotates an object a given number of degrees around a specified axis.
Inline mode usage
rotate -h
Displays the help file that summarizes the parameters for this command.
rotate –all –p <x1 y1 z1> <x2 y2 z2> <angle>
Rotates all objects from start point <x1 y1 z1> to final point <x2 y2 z2> with angle <angle>.
Interactive mode usage
Invocation
rotate or rotate -all
  • Objects to rotate (when not specifying the all modifier).
  • First point of rotational axis.
  • Second point of rotational axis.
  • Angle to rotate, in degrees.
We want to create a circle lying on the XZ plane. To do this, we create a circle using the circle command. This circle will lie in the XY plane:
>circle
Center [x y z] 0 0 0
Radius [double] 2
Then, we will rotate this circle by 90 degrees around the Z axis. For that operation, we will use the rotate command:
> rotate
Select objects on screen (Press enter when done) // Select the circle
Select first point [x y z] 0 0 0
Select second point [x y z] 1 0 0
Select angle (double) 90
Figure 1. Circle lying in the XZ plane
