semicircle
This command draws a semicircle in the geometry.
Inline mode usage
semicircle -h
Displays the help file that summarizes the parameters for this command.
semicircle –n <name> -p <center_x> <center_y> <center_z> <radius> <initial_angle>
Draws a semicircle beginning at the initial angle specified (in degrees) and with the given radius.
Interactive mode usage
Invocation
semicircle
  • Center point of the semicircle.
  • Radius of the semicircle.
  • Starting angle (counted counter-clockwise from the +X axis) of the semicircle, in degrees.
>semicircle
Center [x y z] 0 0 0
Radius [double] 4
Angle [degrees] 45
Result
Figure 1. Resulting semicircle
