splitSurfaces
Split operation on surfaces.
Script usage:
  • splitSurfaces -s surface1 surface2 ... object1 object2...
  • splitSurfaces -s surface1... object1... -c surface2 ... object2...
Screen usage:
  • Invocation splitSurfaces [-c|-tips|-h]
    • no_param: Split between all selected surfaces
    • -c: Selected surfaces are split by the cutting objects
    • -tips: Show the most practical tips on solving unexpected results for this command
    • -h: Print this help
Additional tips:
  • The selected objects must produce intersections on the surfaces.
  • The selected objects cannot have curvatures larger than 90 degrees.
Figure 1. splitSurfaces example
