Output Menu (Alt +O)
This menu allows the user to set different parameters that determine what results are calculated in the simulation. Depending on the simulation type selected in the Simulation Parameters menu, the options shown in this menu will be different:
- If “ RCS & Field” or "Field" simulation type are selected, the Observation Directions option will be shown in the Output menu.
- If “ Coupling” simulation type is selected, the Coupling option will be shown in this menu.
- If “ Doppler” simulation type is selected, the Output menu is not enabled.
Next, the different Output options are explained in detail:
