Example 1: Monostatic RCS of a Sphere and a Box
In this example, the Monostatic RCS of a box and a sphere is calculated.
Step 1
Start newFASANT.
Step 2
Select File and click on New.
Step 3
Select GTD-PO.
Figure 1. Method Type selection
Step 4
Click on Geometry→Solid→Sphere, which requires the center and the radius, as shown in the next Figure.
In this example the user enters the following values into the command line:
  • Center: 0 0 0
  • Radius: 1.0
Figure 2. Create sphere command
Step 5
Click on Geometry → Solid → Box, which requires the first corner of the base, width, depth, and height as shown in the next Figure.
  • First corner base: 2.5 -0.5 -0.5
  • Width: 1.0
  • Depth: 1.0
  • Height: 1.0
Step 6
Click on Simulation → Parameters.
Step 7
On the top left side of the newFASANT window, the user can enter the desired parameters for this simulation, as shown in next Figure.
Select 1 bounce (simple reflection) and a frequency of 3.0 GHz and left-click the Save button.
Figure 3. Simulation Parameters panel
Step 8
Select RCS → Parameters.
Figure 4. RCS menu
Step 9
This command appears at the top left side of the newFASANT window as shown in the next Figure.
Select Monostatic RCS only.
Figure 5. RCS panel
Step 10
Select Source→ Parameters.
Figure 6. Source menu
Step 11
Introduce the source position (r, theta, and phi), as shown in the next Figure and left-click on the Save button.
Figure 7. Source panel
Step 12
In the Output tab, introduce the observation information sweep on theta with 181 samples.
Figure 8. Observation directions panel
Step 13
Before running the case, select Meshing → Create Mesh.
Figure 9. Meshing menu
Step 14
Select 1 processor and define the curvature mesh option with a distance error of 0.01 and surface error of 0.08 and left-click on Mesh.
Figure 10. Meshing panel
Left-clicking on Mesh launches the meshing engine as shown in the next Figure:
Step 15
To obtain information about the mesh, select Meshing →Visualize Existing Mesh.
Figure 11. Meshing visualization
Step 16
Select Calculate → Execute and select the number of processors available to simulate this case.
Figure 12. Calculate panel
Figure 13. Process Log panel
Step 17
When the simulation finishes we can visualize the simulation results. Click on Show Results →RCS→ View Cuts, which allows the user to see the RCS graphic.
Figure 14. Show Results menu
Figure 15. RCS visualization
Step 18
Click on Show Results → RCS → View Text Files. Then select the Steps and press OK to see the RCS data file.
Figure 16. File text panel
Step 19
Click on Show Results → Ray Tracing → View Ray. It is possible to represent the ray tracing of the sources interacting with the geometry
Figure 17. Show Results menu
Figure 18. Ray-tracing visualization
