Simulation Cases Menu
The options under this menu allows the user to manage the list of simulation cases of the project. The following figure shows the contents of the "Simulation cases" menu:
Figure 1. Simulation Cases menu
The available options under this menu are the following:
- New case Allows the user to create a new (empty) simulation case.
- View/Edit case This submenu will list the simulation cases of the project. Clicking on any of them allows to edit the parameters of the case.
Any of these options will open the Simulation Case Editor to edit the parameters of the new or existing simulation case.
