Parameterization in Calculated Columns
Given Table 1:
Group |
Name |
Value |
X |
A |
2.00 |
X |
B |
3.00 |
Y |
C |
4.00 |
Creating a new numeric parameter X with a value of 7:
Then adding calculated columns AddOne = [Value] + 1 and AddX = [Value] + {X} will result to:
Group |
Name |
Value |
AddOne |
AddX |
X |
A |
2.00 |
3.00 |
9.00 |
X |
B |
3.00 |
4.00 |
10.00 |
Y |
C |
4.00 |
5.00 |
11.00 |
Sample 1
Below is the defined breakdown in a Table visualization:
This Table visualization is showing the grouping of the columns based on the breakdown hierarchy with AddOneSum, AddXSum, AddOneCalc, AddXCalc as Visual Members with the corresponding aggregates and the X value is set to 7:
Column |
Aggregate |
Value |
Sum |
AddOneSum |
Sum |
AddXSum |
Sum |
AddOneCalc |
Calculation |
AddXCalc |
Calculation |
Adding an Action Dropdown in the dashboard with a Set Parameter mode:
And given Table 2:
Value |
0 |
1 |
7 |
12 |
Will result to these Table values:
