Altair® Panopticon
Modifying User-Defined Columns
A generated column can be modified.
1.     Modifying user-defined columns can be done either by clicking:
·         the Edit  button of a generated column title in the Data Preview
·         the Calculated Columns button on the Data Sources Settings pane and clicking the generated column to be modified.
The corresponding user-defined settings is displayed.
2.     Modify the properties or settings and click  to save the changes.
