Altair® Panopticon
Panopticon Visualizations
Panopticon supports a wide range of information visualizations that are designed for fast comprehension and easy interpretation of static, time series, real time streaming, and historic data sets.
As no visualization is ideal for every purpose, the appropriate visualization for the analytical task at hand must be used. Here are some general recommendations:
Analytical Task
Recommended Visualization
Read numeric values quickly
Table / Pivot Table
Performance against a KPI
Bullet Graph, Tile, Ticker Tile, Donut Gauge
Performance across a single variable for a small number of data elements, with different magnitudes
Bar Graph, Tile, Ticker Tile
Performance across a single variable for a small number of data elements, each with similar magnitudes
Dot Plot
Performance across a single variable for a large number of data items
Heat Map
Performance across a single variable for a large number of data items, which have different importance values
Treemap, Circle Pack
Performance across a hierarchical or grouped dataset
Correlation between two categories of data
Heat Matrix, Network Graph
Relationships between categories of data
Network Graph
Correlation between two or more numeric data columns
Scatter Plot
Geographic correlations of data
Map Plot
Geographic Scatter Plot
Correlation over both a single numeric data column and various categories of data
Dot Plot
Trending performance across ordered categories
Dot Plot
Trending performance between two numeric variables
Numeric Line Graph
Trending performance between three numeric variables
Surface Plot (& 3D)
Trending performance across time
Line Graph
Time based Ranking
Line Graph with Ranking Axis
Time Based Contributions
Stack Graph
Time Based Correlations between time series
Horizon Graph
Time Based Transactions
Needle Graph
Financial Time Series Distributions
Candle Stick or OHLC Graph
Auction Price & Interest/Volume Distribution
Numeric Needle Graph
Geospatial Area Densities
Shapes
Spread between two time series
Spread Graph
Table / Pivot Table
For more information on these visualizations, refer to the Altair Visualizations document.
