Altair® Panopticon
Double Click Mode
This setting determines the action that will be performed when double-clicking on a visualization value.
q  Inherit
The action is inherited from the set double-click option under Workbook properties. The default is Drill. Other options are Filter In, Default Action, or None.
q  Drill
Drills into lower level details of the selected item.
q  Filter In
Filters the dashboard to include selected items.
q  Default Action
Performs the default Action that is defined for the selected item.
q  None
Disables the double-click feature.
