Altair® Panopticon
Cross Tab Axes
Visualizations that support cross tabbing, include the following settings for both the X and Y axes.
Setting
Leaf Bar Thickness
The thickness of the leaf or lowest level of data. The default value is 80.
Leaf Label Angle
The Label angle of the leaf or lowest level of data of the crosstab axis. Default is 0, accepts values between -90 and +90.
Inner Bar Thickness
The width or height allocated for the non-leaf components of the crosstab axis in pixels. Default is 80.
Inner Label Angle
The angle of the non-leaf labels. Default is 0, accepts values between -90 and +90.
Min Interval Length
The minimal interval in pixels between cross tabbed visualizations. Default is 100.
Max Interval Length
The maximum interval in pixels between cross tabbed visualizations. Default is 400.
Word Wrap
Determines whether to wrap the crosstab axis text.
