Altair® Panopticon
Percentile
The selected percentile.
Percentile  is the value of the P-th percentile of an ascending ordered data set containing N elements with values .
There are two steps to compute for Percentile.
1.     Calculate the rank:
The rank is then split into its integer component k and decimal component d, such that ..
2.     Use the formula below to calculate  as:
Sample 1
Consider the ordered list of values 15, 20, 35, 40, 50. What is the 40th percentile of this list?
1.     Calculate the rank of the 40th percentile as follows.
Thus, n=2.6, which gives us k=2 and d=0.6.
2.     Calculate the value of the 40th percentile.
Thus, the value of the 40th percentile of the ordered list 15, 20, 35, 40, 50 is 29.
Sample 2
Consider the ordered list 1,2,3,4. What is the 75th percentile of this list?
1.     Calculate the rank of the 75th percentile as follows.
N = 75/100(4-1) + 1 = 3.25
Thus, n=3.25, which gives us k=3 and d=0.25.
2.     Calculate the value of the 75th percentile.
Thus, the value of the 75th percentile of the ordered list 1,2,3,4 is 3.25.
Sample 3
Given the following sample fields:
Number
Arbitrary
Negative Values
Positive Values
One
Binary
Currency
Decimal
1
3
-1
1
1
0
$1.00
1.01
2
2
-2
2
1
$10.00
2.02
3
1
-3
3
0
$100.00
3.03
4
0
-4
4
1
$1,000.00
4.04
5
-1
-5
5
0
$10,000.00
5.05
6
-2
-6
6
1
-$1.00
6.06
7
-3
-7
7
0
-$10.00
7.07
8
0
-8
8
-$100.00
8.08
9
0
-9
9
-$1,000.00
9.09
10
0
-10
0
$0.00
0.00
Sample fields.
The 50th Percentile value for each field in the table:
5.50
0.00
-5.50
4.50
1.00
0.00
0.50
4.55
5.50
0.00
-5.50
4.50
1.00
0.00
0.50
4.55
The results per field.
