Altair® Panopticon
Grouped Needle Graph Settings
The grouped needle graph settings pane is displayed after clicking the Options  button.
Setting
Needle Width
Specifies the width in pixels for each needle:
Show Borders
Determines whether borders are drawn around needles. These are only visible if the Needle Width is greater than 1 pixel.
Show Coordinates
Determines whether the graph coordinates (i.e., X-Y plots, or Date/Time-Y plots) on mouse over are displayed in the visualization.
Other visualization-specific properties can be set by clicking on the Y-Axis variable drop area and then selecting the Y-Axis tab:
Setting
Independent Y-Axis Scaling
Determines whether to have each visualization Y-axis in a cross tab automatically scaled independent of the others.
