Altair® Panopticon
3D Scatter Plot Settings
3D Scatter Plots are a 3D perspective version of the 2D Scatter Plot. They provide a clearer understanding of physical shapes in a 3D space. The Scatter Plot 3D is made up of a series of points where each point has X Position, Y Position and Z Position.
In addition, items can be sized by numeric data values, and colored by numeric or text data values. Items can also be shown as different shapes – either standard shapes available in Panopticon or custom shapes that you add to a custom shape palette.
The 3D Scatter Plot settings pane is displayed after clicking the Options  button.
Setting
Show Borders
Determines whether borders are visible around each scatter point.
Show Labels
Determines whether labels will be displayed. If enabled, select how scatter point labels are shown:
·         Distinguishable
·         All
Min Radius
The minimum radius in pixels of the scatter point.
Max Radius
The maximum radius in pixels of the scatter point.
Show Axes
Determines whether axes are displayed.
Show Axes Titles
Determines whether axes titles are displayed.
Show Ground Plane
Determines whether the ground plane is displayed.
