ksqlDB - Streaming
The ksqlDB - Streaming connector allows executing ksqlDB push queries.
1. Select ksqlDB – Streaming from the Data Sources pane. The ksqlDB - Streaming Settings pane and the retrieved ksqlDB - Streaming source are displayed.
2. Enter the Name of the ksqlDB - Streaming data source, then click .
3. Enter the following properties:
Property |
Description |
Server URL |
ksqlDB - Streaming host address. |
Username |
User Id that will be used to connect to ksqlDB - Streaming. |
Password |
Password that will be used to connect to ksqlDB - Streaming. |
4. Check the Collection box to enable and select either:
· Stream
Immutable and append-only collections which are useful for representing a series of historical facts. Adding multiple events with the same key allows these events to be appended to the end of the stream.
· Table
Mutable collections. Adding multiple events with the same key allows the table to only keep the value for the last key. This collection is helpful in modeling change over time and often used to represent aggregations.
5. Click to populate the drop-down list. Select the collection.
6. Enter an SQL-like query language into the Query box.
7. Check the From Beginning box to subscribe from the beginning to the latest messages.
If un-checked, you will only be subscribed to the latest messages.
8. Enter the Timeout. Default is 5 (in seconds).
9. Select either the dot (.) or comma (,) as the Decimal Separator.
10. Click to the fetch the schema based on the connection details. Consequently, the list of columns with the data type found from inspecting the first ‘n’ rows of the input data source is populated and the Save button is enabled.
This also populates the Id Column with the set of columns, of arbitrary type, that can be concatenated to form a unique row identifier.
11. You can also opt to load or save a copy of the column definition.
12. Click . A new column entry displays. Enter or select the following properties:
Property |
Description |
Name |
The column name of the source schema. |
Type |
The data type of the column. Can be a Text, Numeric, or Time |
Date Format |
The format when the data type is Time. |
Enabled |
Determines whether the message should be processed. |
To delete a column, check its or all the column entries, check the topmost , then click .
13. Date/Time values of output data and Date/Time inputs, where supported, is by default unchanged.
14. For this section:
Refer to Define Real-Time Settings for more information.
15. Set the row limit of the data set.
16. Tap the Preview Selected Data Source slider to turn it on.
17. Click to display the data preview.
