Altair® Panopticon
Creating a New Text Color Palette
The configuration pane for the Color variable changes depending on the column data type.
In the Web Authoring, when a text column is added to the Color variable, the configuration pane displays the color associated with each categorical item, as specified with a default color palette (e.g., Twenty Eight Colors).
1.     On the Text section, click the New  icon.
The Next Text Palette dialog displays.
2.     Enter the Title then click .
3.     Select the Number of Colors in the drop-down list. Default is 28 colors.
The Other list is updated accordingly.
4.     To set the colors:
·         click the corresponding Color box to display the Color dialog to:
¨        select the color, or
¨        click  to enter the values
for RGB
for HSL
for the Hex color code
·         or enter the Hex color code
5.     Click .
The new text color palette is added in the list (e.g., Sixteen Colors). Note that it can be deleted.
