Text Axis Variable Configuration for the Text Combination Graph
The Text Axis Combination graph has a time time axis variable that you can configure. There is no need to drag and drop columns to this variable.
1. Click on the Text Axis variable drop area of the Text Combination graph. The Text Axis Settings pane displays.
2. Define or select the value of the following settings:
Setting |
Description |
Leaf Bar Thickness |
The thickness of the leaf or lowest level of data. The default value is 40. |
Leaf Label Angle |
The Label angle of the leaf or lowest level of data of the crosstab axis. Default is 0, accepts values between -90 and +90. |
Inner Bar Thickness |
The width or height allocated for the non-leaf components of the Table axis in pixels. The default value is 40. |
Inner Label Angle |
The angle of the non-leaf labels. Default is 0, accepts values between -90 and +90. |
Min Interval Length |
The minimal interval in pixels between cross tabbed visualizations. Enabled by default and the value is set to 20. |
Max Interval Length |
The maximum interval in pixels between cross tabbed visualizations. Tap the slider to enable. The default value is 400. |
Word Wrap |
Determines whether to wrap the visualization axis text. |
3. Click the Save icon on the toolbar.
When
saved, the notification
is displayed.
