Altair® Panopticon
Toggling Between Rows and Columns of a Cross Tab
This feature supports the easy swapping between rows to columns, and vice versa in, the pivot points of a cross tab.
In a visualization that is cross tabbed, right-click on row or column and select Swap Columns and Rows on the context menu.
The rows and columns will be swapped in the Columns or Rows section of the visualization.
You can opt to revert to the original columns of the Columns and Rows by selecting the Swap Columns and Rows on the context menu.
