Alerting
The Alerts
function allows to notify you when the data in a visualization has
met your predefined settings.
If alerts
are required to be sent via email, the following properties must be
configured first in the Panopticon.properties
file.
Property |
Alert |
Attribute |
alert.creation.only.by.administrators |
Description |
Enable or disable whether only Administrators
can create alerts. |
Default Value |
false |
Property |
Alert |
Attribute |
email.address |
Description |
The email address where the alert will be
sent from. |
Default Value |
Property |
Alert |
Attribute |
email.password |
Description |
The email password, if available. |
Default Value |
Property |
Email |
Attribute |
email.host |
Description |
The host name used by the email server. |
Default Value |
Property |
Email |
Attribute |
email.port |
Description |
The port number used by the email server. |
Default Value |
Otherwise,
when trying to enable an alert, this error will be displayed:
Save the updated
file and restart Tomcat.
