Uploading a Data Table
A user with an Administrator role can upload data tables in the Panopticon Visualization Server.
1. Click the button.
The Upload Data Table dialog displays.
2. To upload a data table, either:
· drag the file from your desktop and drop on the dialog, or
· click Choose datatable and then browse and select one on the Open dialog that displays.
The name of the data table is displayed on the uploaded data table area and in the Name box.
3. You can opt to rename the uploaded data table.
4. Check the Replace existing datatable template box to replace the previously published data template with the same name to the new one.
5. Check the Update referring workbooks box to update the workbooks associated with the data template.
6. Click .
The uploaded data table is added in the list.
