Modifying Parameters
1. On the Parameters tab, click
the Edit icon of a parameter.
The Name, Value, and Encrypted controls are enabled.
2. Make the necessary changes then click
NOTE |
For the inherited parameters, the Name and Type are not editable.
Once the value of the inherited parameter is changed, it is displayed as a global parameter and can also be deleted.
